Drop in boost
Old May 22, 2009 | 09:20 PM
cossie daz's Avatar
cossie daz
Default Drop in boost
my stage3 cossie running 25psi and now its just dropped down to 14psi and wont go above
Old May 22, 2009 | 09:33 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
First thing that comes to mind is the amalvalve not working anymore. If that's the cause then it wont be bleeding any air out to the airfilterbox but will send all the boost directly to the actuator causing it to open much earlier. So less boost.
JamesH's Avatar
JamesH
Could be loads of things Daz,
Amal valve, weak actuator etc
Old May 22, 2009 | 09:49 PM
cossie daz's Avatar
cossie daz
hi james ,i thought amal valve but wasnt sure
Old May 22, 2009 | 10:02 PM
Alvyn's Avatar
Alvyn
it's got a big air leak!!!! d/v a good starting point if ones fitted!!
Old May 22, 2009 | 10:29 PM
JamesH's Avatar
JamesH
Yeah diaphram can go in dv
Old May 22, 2009 | 10:32 PM
BigErn's Avatar
BigErn
amal, actuator and check for air leaks are first and foremost to check.
Old May 24, 2009 | 06:56 AM
DV easy to check, stick a round bit of wood in place of it and try it.
Old May 25, 2009 | 08:10 AM
cossie daz's Avatar
cossie daz
cheers tabetha, will try the DV i may take it apart as a spec r one and only 3 bolts .
thanks
Old May 25, 2009 | 08:25 AM
Only this week, well yesterday fitted my new Collins diaphragm in my dv, old one kept sticking and all sorts.
It was acting a bit odd to start with, a bit lazy, but noticed it was not super flexible like the old one, which was now torn, and very mishapen.
After around 10 miles all good, hadn't realised it must have been leaking boost all the time, as it's defo pulling harder lower down from 1800rpm, and noticebaly faster all the way, one of those things that happens so slowly it doesn't get noticed, it laso idles better now, even with ignition smoothing off!!
Good luck with the boost hunt anyway,
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Marv888
Sep 26, 2015 03:44 PM
Russ Payne
Sep 25, 2015 08:29 PM
