cooling fan issues - fiesta
Old May 22, 2009 | 02:59 PM
apwcoachworks's Avatar
apwcoachworks
Default cooling fan issues - fiesta
I have fitted a new cooling fan on a 53 plate fiesta and now its not working! I have given it direct power and it spins up fine but when the engine runs up to temperature its not cutting in.
Help!
Old May 22, 2009 | 05:39 PM
When engine is running check whether the permanent supply is live or neg, so obviously the other one is switched and is missing, if it has a rad fan switch(might be ecu controlled) bridge switch, if it nows works, replace switch, don't overly rely on gauge temp to be accurate though.
rex647
Mar 6, 2022 06:20 AM
simonmcf
Sep 22, 2015 08:40 AM
Vacuman
Sep 11, 2015 11:37 PM
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
