cosworth block Q
Old May 16, 2009 | 05:42 PM
damian harris's Avatar
damian harris
sideways most if the time
Default cosworth block Q
Is there any other block that will fit a cosworth top,i.e transit or 2.0 pinto ect?
Old May 16, 2009 | 05:55 PM
Transit or pinto both fit,
Old May 16, 2009 | 05:56 PM
jacko's Avatar
jacko
why what you thinking
Old May 16, 2009 | 06:03 PM
damian harris
just to see what the diffrence is in power ect.and are they cheapern to fix.
Old May 16, 2009 | 06:04 PM
jacko's Avatar
jacko
they are weaker by far mate as the 205 block was picked for its strength from pintos and the 200 was a stronger version
Old May 16, 2009 | 06:54 PM
damian harris
Is the cosworth blocked stamped up any diffrent,any numbers to look out for
Old May 17, 2009 | 05:21 PM
nicksaph's Avatar
nicksaph
2.0injection used a 205 block
cosworth block userly has a YB no. stamped just above the water pump mate
not sure of any outher differences
original
Apr 28, 2026 05:20 PM
James Porter
Oct 28, 2015 12:17 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
