innovate lc-1 any experts?
Old May 16, 2009 | 05:08 PM
col93saphcos's Avatar
col93saphcos
Default innovate lc-1 any experts?
hi,any experts know about these things?have lc-1 and db gauge thing,reading the instuctions it says its possible to use it instead of standard lambda,but does it still use that gauge?maybe gauge of other output?is this ok to do with a 4x4 saph cossie with lambda as standard?also do i need to make a heat sink?probably think up more,lol,but thats it for just now,thanks col93saphcos
Old May 16, 2009 | 05:16 PM
KSA-Cossie's Avatar
KSA-Cossie
Ask stu tonight col he has one so does brian iirc.
Old May 16, 2009 | 05:21 PM
grcossie's Avatar
grcossie
It`s 2 analog output, that can be used for engine managment on this innavate, te gauge will still be used to show wideband lambda. I use mine whitout heat sink fore some years now, whitout problem. You can also connect it to your laptop to adjust analog signal and a lot more, easy to use.
Regards from Norway
Old May 16, 2009 | 06:06 PM
zetecdan's Avatar
zetecdan
there is an innovate forum with various sections including one for the lc-1 which i have used to answer any questions i had about installing my lc-1 and db gauge.
see here http://www.innovatemotorsports.com/forums/index.php
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
CasperR
Apr 2, 2005 10:21 AM
21
Sep 4, 2004 09:27 PM
