engine year
Old May 15, 2009 | 08:16 PM
samy66's Avatar
samy66
Default engine year
got an 2.0l mondeo engine silver top. think it is an 1998 engine but is there any way of knowing the specific year cause they have different stuff up to 5/98 and after 5/98. ant help is very welcome.cheers
Old May 15, 2009 | 08:18 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
silvertop is up to 98 i think
Old May 15, 2009 | 09:00 PM
samy66's Avatar
samy66
what did tit change to black top after
Old May 16, 2009 | 12:42 AM
pdfbt40's Avatar
pdfbt40
Blacktop was introduced on Manufacture Date 1/6/98. Initially with an alloy cam cover before it changed to plastic (and a few other minor mods) about a year later, so don't go by that.
Obvious differences on the Blacktop are that the oil filter is screwed direct on the block, and waterpump & its drive are offset from the centre of the engine to the front.
Martin
Old May 16, 2009 | 05:18 PM
samy66's Avatar
samy66
cheers just wanted to make sure i get the right parts when i order stuff.
Old May 17, 2009 | 05:24 PM
nicksaph's Avatar
nicksaph
if the engine no. is still on the engine you can tell what month and year the engine was built
cheeRS nick
Old May 17, 2009 | 09:53 PM
pdfbt40's Avatar
pdfbt40
Wink
True, but whilst the year code is almost easy, the sequence of the month code is a bit
As the real query was actually about whether it was a Silvertop or Blacktop, I thought it's easier to compare
the oil filter mounting rather than the '98 (W) 'sequence' of
April - WT
May - WJ
June - WU
July - WM
Martin
track.focus'd
Aug 12, 2015 05:53 PM
