whats the right way to wire a live to amp my speakers?
I already have a sub and amp in the boot, now im looking to amp my components. I can fit amps, just need to know the right way to run 2 amps. I have one already in boot with my Focal sub, now I am looking to add one to the front and amp my speakers. Do i cut into the power cable and add a new live wire to run the 2nd amp off? This will be situatated under dashboard, if so what rating fuse do i need.
Or do I run a new fuse/live cable from battery, through bulkhead to new amp. This I dont want to do due to yet more cables running through bulkhead......
You can do as you mention in the first option, if the cable is heavy enough, for fuse rating just see what is on the amp already, they already have a inbuilt replaceable fuse, just put same one in.
get a better cable from the battery (£30 halfords) , then a fuse splitter, then 2 wires coming from the fueses to your amps.
ive got pics of mine if you want to see them
Mark RS
12-10-2015 06:01 AM
