Sapphire abs problem
Old May 7, 2009 | 03:21 PM
capri280's Avatar
capri280
Default Sapphire abs problem
Need the get my abs sorted for the not
Light is staying on in the dash
Where do I start and what do I need to do to get it functioning correctly
Old May 7, 2009 | 08:05 PM
funkybrian's Avatar
funkybrian
Alright mate get yourself a multi meter and unplug the abs sensors test the sensors for resistance ( 1.200 to 1.600ohms) if you have a knackered sensor it will should no resistance. if they all ok turn the multi meter to millie volts and spin the wheel the voltage should jump about if not you have a air gap problem or something up with abs ring
hope that helps cheers brian
Old May 7, 2009 | 08:17 PM
jason_nike's Avatar
jason_nike
Wire it into the handbrake connector in back of panel, handbrake off, light comes off and so does abs light
tib2220
Sep 14, 2015 12:33 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Tony W
Sep 9, 2015 12:08 PM
