Tick over proplems on rs 2000 mk5
Old 27-04-2009, 08:00 PM
Denzil
Denzil's Avatar
Default Tick over proplems on rs 2000 mk5
hi i need some help on this its just started i seem to find my car wont idle ob 1000 it keep going on 1000 then to 900 up and down up and down some times it does it some times it dont and some times wen iam driving it keep cutting and pulling like it running out of petrol only 4 a second but its bugging me that wen iam in rush hour traffic it wants to cut out any ideas wat this could be thank you
Old 27-04-2009, 10:06 PM
martysmartie
martysmartie's Avatar
Have you checked your TPS sensor it may need adjustment other possible culprit is the ECT (Coolant sensor) the fact that your idle flutuates suggests the ISCV to be working but it may be as well to remove this and clean with some light oil as these are well known to jamming.
Martin.
Old 28-04-2009, 07:36 AM
Denzil
Denzil's Avatar
tcp and ect were abouts are thay located under the engine thanx
Old 28-04-2009, 07:51 AM
martysmartie
TPS (Throttle Position Sensor) and ECT (Engine Coolant Temperature) TPS is located on throttle body and it's job is to feedback information to the ECU about the position of the butterfly. The signal range is from 0-5V if you search on here there is instructions on how to set these up and a way how to test them.
ECT tells the ECU information about the engine coolant temperature and it then can perform enrichment for cold starts etc.
Martin
rex647
06-03-2022 06:20 AM
gambo08
04-02-2016 10:49 PM
07-10-2015 12:56 PM
little bram
27-09-2015 07:45 AM
morg65
Escort MK 5 / MK 6
23-09-2015 03:19 PM
Quick Reply: Tick over proplems on rs 2000 mk5
