escort temp sensor problems (HELP)
Old Apr 23, 2009 | 01:39 PM
blackgti's Avatar
blackgti
Default escort temp sensor problems (HELP)
hi there all i've got a 97 escort gti 1.8 the temp sensor for the temp display is faulty it won't work i've replaced sensor several times now each time the sensor works for a few days then it starts playing up to start with the temp gauge goes all the way to the top and the battery light comes on but if you rev the engine it drops back to normal and the battery light goes out it does this for a few days then packs up alltogether again any advice appriciated
Old Apr 23, 2009 | 03:26 PM
I would start by cleaning all the earths coming from engine/battery, though this is an odd problem, I'm thinking maybe your alternator is spiking.
It's a pitty you can't measure the voltage when this happens.
Old Apr 23, 2009 | 07:16 PM
blackgti's Avatar
blackgti
Do you think it would help to put a new alternator on as well as clean the earths cheers
Old Apr 24, 2009 | 05:38 PM
I wouldn't until 100% positive that the present one is faulty, a dodgy connection is more likely, and cheaper, in any case just a new regulator/rectifier can be fitted to yours, or even recon exchange for less than around Ł50.
Old Apr 24, 2009 | 06:47 PM
blackgti's Avatar
blackgti
Cheers then tabetha got perfect chance tomorrow fitting a new gearbox so i'll check round all the earth connections whilst doing that
Old May 8, 2009 | 04:24 PM
blackgti's Avatar
blackgti
Where abouts is this sensor on the block mate i've already changed the two on the thermostat housing cheers
Old Jan 30, 2010 | 06:29 PM
cybercypher's Avatar
cybercypher
Default same problem here :(
Hi blackgti
did you sort the problem?
as i would like to know as mine has started doing it
no temp at all then all of a sudden it goes into the red and after a bit it settles down to opperating normally
also the battery light comes on
any help would be great
Old Jan 31, 2010 | 05:07 PM
blackgti's Avatar
blackgti
hi cybercypher i tried everything in the end it turned out to be some wiring on the main loom going into the fuse box that was at fault it had been rubbing and worn through did my head in took it to garage to sort in the end good luck with yours mate
Old Jan 31, 2010 | 06:32 PM
martysmartie's Avatar
martysmartie
Check earths itself, I would think it could be sorted if not with a new regulator and not need a whole new alternator. Check battery voltage with car running and see if it's above what it should be.
Martin
Old Jan 31, 2010 | 08:11 PM
cybercypher
Angry
well al being well im having a alarm fitted this week by an auto electrian so while he is there ill get him to look into it, as he'll proberly know where to look for the fault
its driving me nuts
i do think it is an electrical fault cos the engine temp goes to red and the battery light stay on when you start the engine, when you rev it the battery light goes off and temp guage goes down.
also the light of the clock is intermitant as well.
we'll wait and see what he says
Old Apr 14, 2013 | 02:16 PM
Dwve576's Avatar
Dwve576
its driving me nuts
Did anyone fine out what the problem was mine does exactly the same, somebody has fitted a switch to the live on the battery to the altinator when u flick it on then off the light goes off but id rather have it fixes properly
Dave
Vincereese
Jun 1, 2023 09:14 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
