Alternator wiring. Need help please!
Old Apr 19, 2009 | 04:21 PM
Recogniseman's Avatar
Recogniseman
passioNoob
Default Alternator wiring. Need help please!
I have recently swapped the engine in my fiesta from a 1.25 to a 2ltr Zetec E (originally from a mondeo).
I have got the engine running however the alternator is not recharging the battery. The alternator from the old 1.25 had a 2pin plug and Joined the old loom. The alternator on the Mondeo engine however has a 3 pin plug and I am unsure how to connect it to the old fiesta loom or via the ECU I am now using (Independant Pectel T2). Can anyone tell me what each of the three pins is for on the Mondeo 2lt alternator? Then I would stand a chance at finding out how to wire it up correctly to the clocks in the dash and also to charge the battery etc. I cannot use the old 1.25 alternator as it is a different design and will not mount to the engine.
Any help greatly appreciated
Rob
Old Apr 19, 2009 | 07:39 PM
Recogniseman
passioNoob
In addition to make it clear. The alternator is already connected to the battery via the larger 10mm stud. The small plug socket has the three pins that I need to identify.
cheers
Old Apr 19, 2009 | 09:23 PM
cabriolet's Avatar
cabriolet
what year mondy fella early ones easy later ones controlled by ecu bastard r there any numbers on the alternator post them here then i can give u more info
Old Apr 20, 2009 | 09:34 PM
Recogniseman
passioNoob
it's a Bosch BR1-3 14V. Do the older type mount the same way? if so Maybe I should try and swap it for a simpler, older one.
Thanks for any help.
Old Apr 22, 2009 | 05:26 PM
cabriolet's Avatar
cabriolet
is there not a 0124?????? number on the alternator fella all that number is is a product code
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
