t3 turbo fitting help
Old Apr 18, 2009 | 04:37 PM
mark106mark's Avatar
mark106mark
Default t3 turbo fitting help
Hello
I am in the process of changing my T3 turbo on my escort s2 rs turbo....problem I have is my old turbo is oil cooled only nad the new one is oil and water cooled. Where should I plumb the water feed to the turbo from.
I have a blank on the radiator so can take one from there but where should I plumb the return pipe??
Any help appreciated!!
cheer mark
Old Apr 18, 2009 | 04:51 PM
Rob Virgo's Avatar
Rob Virgo
if its lke a cossie then you can leve the water cooling disconnected,really not needed on a road car .as a bonus you put less stress on your cooling system.should get an rst expert to confirm tho.
rob v
Old Apr 18, 2009 | 04:52 PM
RS 5tu's Avatar
RS 5tu
You dont need to run the water feed if you dont want.
It only help warms up and cools down quicker but will be fine with out.
Old Apr 18, 2009 | 04:55 PM
mark106mark
Thanks for the reply lads.....
So it would be fine to blank off the holes then and just run the oil feed?
Old Apr 19, 2009 | 02:49 PM
mark106mark
Anyones further advice is appreciated on this......
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
marky_g
Aug 15, 2015 10:43 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
