smoking 2wd under load
Old Apr 9, 2009 | 10:43 PM
cossiedan1983's Avatar
cossiedan1983
Default smoking 2wd under load
got sapphire 2wd smokes under load, changed stem seals and had turbo reconed, compressions good 7-8 maybe overfuelling temp sensor? causing bore wash help please before engine comes out?fully quallified mechanic so no daft conclusins please! many thanks
Old Apr 10, 2009 | 04:12 PM
siward's Avatar
siward
Have you checked the breathers are not blocked? Do you have uprated breather system?
Old Apr 10, 2009 | 04:56 PM
cossiedan1983
yeah got breather ive tried 10 60 oil which stopped smoked but still used it around a litre to a hundred miles
Old Apr 10, 2009 | 05:01 PM
LHD220Turbo's Avatar
LHD220Turbo
it could be worns oil rings which wont show on a comp test
i guess its blue smoke? if not what colour is it?
what's the idle CO%? do you have an AFR gauge?
Old Apr 12, 2009 | 07:47 PM
cossiedan1983
set co to 3 at work puttin mates wideband on on wed to check down road, its bluey black my mate sez it smells fuely but it uses oil so maybe bore washing oil off being too rich?
Old Apr 12, 2009 | 07:55 PM
TurboShed's Avatar
TurboShed
Cossiemodo
+1
Old Apr 12, 2009 | 08:23 PM
LHD220Turbo
might well be; but obviously, whatever chip you have will determine what the co% is at idle (assuming it is chipped)
if you can open the lid on the ecu and have a look, you'll see a make and serial number hopefully. Phone the chip manufacturer and quote the seial number and they'll tell you what the CO% should be at idle
remember when twiddling with the screw on the ECU, it changes it for the whole Map
Matt
Old Apr 14, 2009 | 07:58 PM
cossiedan1983
its a norris motorsport chip will phone him 2moro
Old Apr 18, 2009 | 09:56 PM
cossiedan1983
3.5% thats roughly wot its set at?
Old Apr 18, 2009 | 10:17 PM
fullyboosted175's Avatar
fullyboosted175
never understand why people run a tuned car without an AFR gauge, it's just asking for trouble, get 1 fitted so you can keep an eye on your fueling, it's just as important as your boost gauge if not more!
mark r
Sep 29, 2015 07:27 PM
Bransby
Sep 21, 2015 05:29 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
turbowag
Sep 3, 2015 08:07 AM
