main beam (s2 rst)
Old Apr 8, 2009 | 03:35 PM
brett_'s Avatar
brett_
Default main beam (s2 rst)
my main beam dont work, wen i flip to main beam my lights just cut out!!??
any ideas ive checked fuse all ok
cheeRS brett
Old Apr 8, 2009 | 03:42 PM
The stalk with the light switch on the mk4 escort can be very troublesome, unlikely that both bulbs have blown, so I would first check for output from the switch when you select mainbeam from dip on the stalk.
Old Apr 8, 2009 | 03:43 PM
paulc18rst's Avatar
paulc18rst
D6 COS
try changing the light switch or, if not, it could be down to an earth somewhere ? i had the same problem and it turned out to be a knackred switch.
Old Apr 8, 2009 | 03:51 PM
brett_'s Avatar
brett_
how do i check for a out put on the stalk???
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 28, 2015 03:03 PM
DavidK
Sep 27, 2015 02:55 PM
