Boost: Peak and hold
Old Dec 2, 2004 | 12:00 PM
XS's Avatar
XS
Default Boost: Peak and hold
I have never had a turbo before and am trying to understand how the turbo works. I have read on the forums about Peak @ 21psi, holding 18psi. How does it work and when does it happen? Is peak boost when the turbo first spools up and you get that initial kick? When it drops from ‘peak’ to ‘hold’ should you be able to feel it? Why can it not peak and hold the same pressure?
Is there anything that can effect the holding pressure? Leaky dump valve? Weak actuator
Any info would be great.
Old Dec 2, 2004 | 06:17 PM
Dave Henshall's Avatar
Dave Henshall
as you said really, the peak is usually the kick and boost noramlly tails off towars th top end of the revs (if the turbo cant flow enough air - like on smaller turbo cars) or the chip has been programmed to do this from a safety point to help protect the engine.
and yes. air leaks including from the DV would affect this aswell as old, sticky weak actuators.
Old Dec 14, 2004 | 07:46 AM
XS's Avatar
XS
Thanks
Stu
Old Dec 17, 2004 | 06:43 PM
Nik_W's Avatar
Nik_W
Weak actuators are a bugger. My first Saph Cos used to peak at 20psi and hold 12psi!!!!!! a brand new -31 soon sorted that.
Old Dec 18, 2004 | 03:31 PM
K18NEO's Avatar
K18NEO
yep, mine boosted at 10psi, and held at 6psi. And that was after the boost controller top fell off, with it on, it boosted at 6psi and held at 4. HAHA. Aswell, a -31 sorted that
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
pabloXR
Sep 21, 2015 12:42 PM
Marino
Sep 12, 2015 11:10 AM
Si B
Sep 12, 2015 06:49 AM
