Spark plug problem for a Zetec E-based engine!
Old Mar 27, 2009 | 04:35 PM
zlatky's Avatar
zlatky
Exclamation Spark plug problem for a Zetec E-based engine!
Hello!...
...I am seeking assistance regarding a problem I faced today concerning the availability of some spark plugs with the following specs:
Thread: 14mm
Reach: 25mm (or 1 inch)
Seat: Tappered
Hex: 16mm
Heat range: NGK: 8 or 9
Champion: C59 or C57
Bosch: 5 or 4 or 3
Denso: 27
Anyone knows where I can find some good quality spark plugs for a Zetec E (2.0 lt / ST 170) based-engine with the above specs?
Thanks in advance for your time!
Old Mar 28, 2009 | 12:19 AM
oilman's Avatar
oilman
The St170 needs these according to the Denso guide
http://www.globaldenso.com/cgi-bin/g...me=&cc=&FF=100. The detail button doesn't give much info though unfortunately. If you want a 27 heat range version, of the ITV24, have a look at these
http://www.opieoils.co.uk/p-4120-den...lug-itv27.aspx
Old Mar 28, 2009 | 04:50 PM
zlatky's Avatar
zlatky
Unhappy
Cheers for the reply!...
...The thing is I couldn't verify all of the needed specs (see initial post in here) in the url's you provided me with!...My ST 170 is kinda "tuned up to the max." lets say, so it's rather crucial that I'll find some decent spark plugs with those specs really!...So far I haven't found any matches unfortunately, and I'm gettin' rather tired / desperate, because I am like one breath away from my final programming / dyno!... :-/
j.hammond1
30
Oct 31, 2021 05:28 PM
Roosie
Aug 15, 2015 08:09 PM
Bobby9779
Aug 11, 2015 06:47 PM
Zoggon
Aug 10, 2015 10:39 AM
adriansaleem
Aug 1, 2015 09:28 PM
