crank position sensor location problem
Old Mar 26, 2009 | 11:18 PM
xrs_man's Avatar
xrs_man
Default crank position sensor location problem
hi, im doing the xr3i to efi turbo conversion using the fiesta ofab ecu and loom, however the turbo engine was mfi and doesnt have a hole for crankshaft position sensor.
has anyone got any ideas on what to do?
thanks
Old Mar 27, 2009 | 06:45 AM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
think you can use a 1800 cvh bottom pully (off the sierra) which as got a triger wheel on it then make i braket to hold the sensor on
Old Apr 8, 2009 | 02:16 PM
xrs_man's Avatar
xrs_man
do i have to use the sierra sensor or xr3i?
and can i just get a 36-1 TRIGGER WHEEL
Old Apr 8, 2009 | 02:19 PM
xrs_man's Avatar
xrs_man
also do you have to have a set distance between sensor and trigger wheel?
Old Apr 8, 2009 | 03:45 PM
You need to use a trigger pattern the same as that on the engine from which the ecu came, it also has to be in the correct place as well, ie the missing tooth must be exactly where it needs to be not just somewhere near, though if having mapped this can be overcome.
The actual sensor does not matter(where it comes from) so long as correct type and fits ok, they can be wildly out distance wise but aim for around 30 thou, or 0.75mm, will be fine.
Old Apr 8, 2009 | 04:34 PM
xrs_man's Avatar
xrs_man
ok thanks.
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
