escort rs turbo dodgy eletrics
Old Mar 22, 2009 | 02:34 PM
rs_turbo_lad's Avatar
rs_turbo_lad
Default escort rs turbo dodgy eletrics
hi, my s2 has jus started acting up. the main headlights are really dull wen switched on [sidelights are brighter]all fuses are fine [tryed new bulbs aswell]
2-and the my central locking has packed up which was a fuse but wen i put a new fuse in it blows straight away,
3-the other prob is the drivers door can be locked with key but cant open with key?
any ideas would be great guys thanks in advance
Old Mar 22, 2009 | 08:05 PM
For the headlights I would look at the earths, you sure it's not a dim dip showing ?
Old Mar 22, 2009 | 08:15 PM
nicksaph's Avatar
nicksaph
hello mate,
ford locks are able to be locked by any ford key mate. you proberly need a new key or at worst case new door lock
as for the central locking problem, did it stop working at the same time as your door lock packed up? if so i would assume there is a problem with the solinoid in the drivers door
cheeRS nick.
Old Mar 23, 2009 | 07:02 PM
rs_turbo_lad
Originally Posted by nicksaph
hello mate,
cheeRS nick.
i had a patch of welding done to my car from aguy, and wen i got it back the central locking wasnt working and the headlights were dull ,the drivers door lock happened later on as car was sitting for couple of month and one day it didnt work
Old Mar 24, 2009 | 12:57 PM
nicksaph's Avatar
nicksaph
if the car hs been welded he might have melted the wire near where he was welding or if he didn't disconnect or put a surge protector on the battery he might have damaged the wiring/central locking solinoide etc
the door lock needs replacing then mate!
cheeRS nick
Old Mar 24, 2009 | 04:29 PM
rs_turbo_lad
cheeRS nick
ok m8 thanks alot, 1 more thing iv just fitted an airtec intercooler and have a slimline fan with 2 wires sticking out from fan ,jus wondering wat wires they need to be connected to get it working ?
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
