Escort Cos side skirts???
Old Nov 30, 2004 | 08:30 PM
M3's Avatar
M3
Default Escort Cos side skirts???
I have removed one of the side skirts off my esc cos, now ive been to ford and ordered some new clips (and what a saga that was ) Prob is there are 2 different types of clip, and one type acording to ford is no longer available, anyone know where else these are avialable.
There is only a very slight difference in these but the skirt won't fit right unless i have both types.
Car is the later type if that makes any difference.
Regards Simon.
Old Nov 30, 2004 | 09:28 PM
Azrael's Avatar
Azrael
I order both kinds and they are the same !!!!
Old Nov 30, 2004 | 09:40 PM
M3's Avatar
M3
There not quite the same, the 2 on the rear section have a slightly small er tag on the back of them to allow the skirts to fit closer to the panel.
I found this out tring to fit them the other way and the bloody thing snapped
Now i cant get them, or at least thats what i was told. will try ford tomorrow.
Old Nov 30, 2004 | 09:49 PM
Azrael's Avatar
Azrael
The ones I got where the same - that's why the back of it stands out a bit
But you ay try the method my body-shop suggested - they just glued this with windscreen glue instead using new clip when one snapped - it holds much stronger.
Old Nov 30, 2004 | 10:28 PM
SteveW's Avatar
SteveW
i have the same problem, ive bought a few of the back type and i'm gonna fit them on the front, going to file the little bits off . so many parts are now obsolite for the escort its a joke, m8 of mine could'nt get a new front hub from ford he had to get one from a breaker
Old Dec 4, 2004 | 01:14 PM
Chris Honeywell's Avatar
Chris Honeywell
they are hard to get hold of there offically discontinued
although i do have 20 in me garage
i was very lucky to get em
Old Dec 4, 2004 | 01:38 PM
bige's Avatar
bige
http://fordpartsuk.com/index.html
Old Dec 4, 2004 | 02:57 PM
M3's Avatar
M3
The rear ones are easy to get, the type with the smaller tag (got 8 spare now) and these will fit the front section ok if carefull when re-fitting
Vincereese
Jun 1, 2023 09:14 AM
Carlbacciochi
24
Jun 30, 2016 04:31 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
