standard sapph cd player
Old Mar 7, 2009 | 03:53 PM
proboscus's Avatar
proboscus
Default standard sapph cd player
i am wanting to put my sapph back to standard apart from engine.i have a couple of 2028 single cd players as used with the 2008 headunit.unfortunatly neither cd player has the right code. i have been told that this model is not the easiest to decode.have found one site that recons they can decode them but its very expesive.does anyone know of anywhere that i can get the codes for this model at a reasonable price or alternativly does the 2040 cd player have the same plugs on the back as the 2028 as i have heard that this model is easier to decode.any help greatly appreciated.
Old Mar 7, 2009 | 05:29 PM
Cossy Mike's Avatar
Cossy Mike
unlucky.....
I was given 2 CD units. One with code not reading discs. The other No code working fine. I managed to take them to bits and make a good one. I also got 2 2008RDS units and A full mint wiring loom but the amp is knackered. It only works 2-channel.
Need an amp!
Best of luck!
Old Mar 7, 2009 | 05:42 PM
KSA-Cossie's Avatar
KSA-Cossie
2028 and 2040 cd players use different amps and have different plugs .
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
