Diagnostic code help
Old Mar 4, 2009 | 06:41 PM
woolford's Avatar
woolford
Default Diagnostic code help
D262 what does it mean in my w reg 2.0 focus??
Paul
Old Mar 4, 2009 | 07:50 PM
studabear's Avatar
studabear
where u gettin the code from, of the displayor a code reader?
Old Mar 4, 2009 | 08:03 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
I got codes beginning with B,P or U nothing with a D, sorry mate!
Take it is an engine code?
Old Mar 4, 2009 | 08:21 PM
cit-tech's Avatar
cit-tech
Transponder (unprogrammed Encoded Ignition Key) 9602 PATS Received Invalid Format of Key-Code From Ignition Key Transponder (Partial Key Code) 9681 PATSTranceiver Signal is Not Received (Not Connected, Damaged, or Wiring) A139 PCM ID does not match between Instrument Cluster and PCM A141 NVM Configuration Failure (No PCM ID exchange between Instrument Cluster and PCM) A143 NVM memory failure 5284 Oil Pressure Switch Failure D027 SCP Invalid or Missing Data for Engine RPM D041 SCP Invalid or missing data for Vehicle Speed D043 SCP Invalid or missing data for Traction Control D073 SCP Invalid or missing data for engine coolant D123 SCP Invalid or missing data for Odometer D147 SCP Invalid or missing data for vehicle security D262 Missing SCP message
nick
Old Sep 10, 2009 | 04:37 PM
VRS's Avatar
VRS
nick
9681 PATSTranceiver Signal is Not Received (Not Connected, Damaged, or Wiring) Is the same fault we are getting with one we have in ! Did you get anywhere with yours ?
Old Sep 10, 2009 | 04:59 PM
woolford's Avatar
woolford
no mate one key work the other doesnt.
Old Sep 11, 2009 | 07:05 PM
fonfe123's Avatar
fonfe123
if one key works but the other doesnt, have you tried to re-code the non working key?
if it wont re-code then replace the key. if one key works then it can not be the wiring or the transponder which only leavesn the key.
you should be able to check if the module is picking up the non working key on IDS though.
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
