Headlight Relays(S2)
Old Feb 22, 2004 | 08:56 PM
AndyGranger's Avatar
AndyGranger
Default Headlight Relays(S2)
The 2 small white relays at the back of the fuse box
Mine keeps blowing the dipped beam relay
Could it be down to fact i,ve put some of those white light bulbs in?
the wiring appears to be ok
Side lights and Main beam work
But when you turn the switch to the dipped beam position everything goes out?
The relay looks well burnt?
Old Feb 22, 2004 | 10:17 PM
dickie's Avatar
dickie
you can get them to come on by cleaning the terminals with emry cloth!
switch the lights on dip, pop the top off fuse box and wiggle till they
come on, they'll then be alright 4a while! think the relays are on there
way out mate, if not the contacts in the fuse box where they plug are dodgy!
happened a couple of times when i had it, been ok 4a while tho.
Old Feb 22, 2004 | 10:22 PM
AndyGranger
I wondered if it might be them bulbs drawing too much current?
I put new relays in b4 you bought it?
Also mate when you did the back brakes did you bleed it with the wheels on the floor?
Old Feb 22, 2004 | 10:25 PM
dickie's Avatar
dickie
try standard bulbs in it 4a while and try it!
na i bled it in the air with wheels off, all bled up ok
and had a good pedel. is there a prob??
Old Feb 22, 2004 | 10:27 PM
dickie's Avatar
dickie
couple of threads in the motorbike section that might interest ya!!!!
Old Feb 22, 2004 | 10:30 PM
AndyGranger
I,m going to bleed them again think i might have cooked them coming off the M1
It,s good to have it back mate
Old Feb 22, 2004 | 10:32 PM
dickie's Avatar
dickie
not good news on the brakes but glad your enjoyin it!
Old Feb 22, 2004 | 10:33 PM
AndyGranger
About 100 down the sliproad thinking "come traffic lights change ya bastids"
Old Feb 22, 2004 | 10:36 PM
dickie's Avatar
dickie
take it they didnt!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
