wiring trouble
Old Feb 28, 2009 | 06:07 PM
actionfighter's Avatar
actionfighter
Question wiring trouble
I recently put a 1600 cvh into my 89 escort it used to be a 1.3 bonus so it has that shitty instrument panel(it has a clock instead of a rev counter)
How do i wire up the panel from an xr3i? any tips?
Old Feb 28, 2009 | 07:42 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
should of replaced the loom for a 1600 one mate
Old Mar 1, 2009 | 08:31 AM
I'd be very surprised if they were different, what I usually do is cut off the connector on the donor car with the clocks and see what's different wiring wise to your car.
Old Mar 1, 2009 | 08:40 AM
iansoutham's Avatar
iansoutham
OCD Victim
You need the connector from the dash clocks you are fitting. Connect each wire together with the same colours. You will then be left with a green wire on the "new" plugs which goes to the coil (or coil pack if you are still running them) and a red wire from the "old" plugs which is not required (+12v).
IF you are still running a coil pack, then you will need a set of XR3i EFi clocks, if running a coil, then all should be good.
Old Mar 1, 2009 | 01:07 PM
actionfighter
thanks for the help lads ill give it a go
Old Mar 1, 2009 | 01:31 PM
I am sure the only wire to move on my old y reg mk2 escort was the green as well.
Old Mar 5, 2009 | 05:19 PM
actionfighter
Well i tried that and everything is working except the fuel gauge i know there is petrol in it but its reading totally empty,and i have all wires connected except the red one and the green for the rev counter any ideas?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
