Driveshaft Woes
Old Feb 24, 2009 | 07:26 PM
42Haya's Avatar
42Haya
Default Driveshaft Woes
I've got all but two bolts out! The others won't come out with my T40 bit.
Suggestions for the other 2?
Where can I purchase more?
Thanks guys.
Old Feb 24, 2009 | 08:41 PM
cabriolet's Avatar
cabriolet
rounded off fella whack in tx 45 or try starting them with a chisel
Old Feb 24, 2009 | 10:30 PM
42Haya's Avatar
42Haya
Cheers mate i'll give that a go tommorow, any idea where i can get new bolts?
Old Feb 25, 2009 | 03:24 AM
Any decent bolt supplier should do these cap heads, just don't use SS ones.
I would either try grips, if enough to grip hold of, or failing that as said chisel.
When you have fitted the new ones, fill the spline/hole with gasket sealant, this goes semi hard after a few weeks, protects the head from corrosion, so next time just dig it out and spline fitting will be fine to use.
Old Feb 25, 2009 | 09:48 AM
42Haya's Avatar
42Haya
Many thanks! Am i right in saying these are M10 x 60mm with a 1.25mm Thread Pitch?
mondeomark
Sep 28, 2015 06:28 AM
rsturbo27
Sep 5, 2015 05:08 PM
Mark Mawson
Aug 31, 2015 07:09 PM
markk
18
Aug 17, 2015 05:19 AM
