90amp alternator pulley swap.
Old Feb 23, 2009 | 02:21 PM
Blakeya's Avatar
Blakeya
Default 90amp alternator pulley swap.
I bought a new 90amp alternator for my 1991 redtop saph cossy. Now, the pulley on the new alt is a multi v pulley & my old alternator has a bouble V-belt pulley. Is what i would like to know is are the pulleys interchangable? If they are i will be fitting my original pulley to the new alternator & visa versa.
Help much apprciated
Regards in advance
Andy
Old Feb 23, 2009 | 02:50 PM
jon@work's Avatar
jon@work
should be and yes
Old Feb 23, 2009 | 02:54 PM
dojj's Avatar
dojj
Resident Wrestling Legend
as long as the body has the same locating bolt holes, then yes, the pulleys "should" just swap over
jam the fan with a srewdriver and undo the hunt, swap the pulley over and tighten up again and refit to the car
Old Feb 23, 2009 | 02:59 PM
Blakeya's Avatar
Blakeya
Cheers chaps,
I assume it's a standard thread & not a left hand thread?
Andy
Old Feb 23, 2009 | 03:29 PM
Std thread, use the thinnest socket you can, as the nuts are very close fit in the depth.
dojj's Avatar
dojj
yup, but just check on the nut to be sure
Old Feb 23, 2009 | 04:05 PM
Blakeya's Avatar
Blakeya
Cheers for the help Peeps. Gonna attack this job tomorrow!!
Regards
Andy
jonfoc
16
Sep 11, 2018 05:35 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
dombanks
Sep 21, 2015 08:38 PM
jay030787
Sep 18, 2015 04:38 PM
