Mondeo troubles
Old Nov 28, 2004 | 01:29 PM
steviep's Avatar
steviep
Default Mondeo troubles
Got a problem wiv my old mans T reg 2.0l Mondeo.
Absolutely fine at tickover, but jerks and seems to missfire under load.It's had new plugs and leads, new air bypass valve and a new air flow meter, but still no different.Funny thing is, it stops doing it if you unplug the air flow meter (hence us fitting a new one) but still the same.
Anyone heard of this before.
Old Nov 28, 2004 | 07:09 PM
steviep's Avatar
steviep
bttt
Old Nov 28, 2004 | 10:18 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
coil pack? summit to do with fueling maybe, cos if u unplug the air mass sensor it'll give more fuel maybe ? plug gaps?
Old Nov 28, 2004 | 10:32 PM
DOO's Avatar
DOO
There a small T piece where the breather hoses meet around the back of inlet manfold by the coil back these split and cause an air leak.worth checking and there only about £3.00 from fords.
Old Nov 29, 2004 | 06:53 PM
steviep's Avatar
steviep
definately no air leak though mate, runs quiet as can be
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
