my cougar
Old Feb 21, 2009 | 07:40 PM
nixy's Avatar
nixy
Default my cougar
i have been told the bottom end is gone any one know if they mean the bearing shells on the crank
Old Feb 22, 2009 | 11:32 PM
louie1's Avatar
louie1
if you rev the car up does it have a low down thumping noise , if so bottom end gone!
Old Feb 23, 2009 | 07:32 AM
Bottom end generally means crank/shell wear, put the car on concrete get someone to gently blip the throttle just above tickover you will feel the vibration from the wear if this is the case, failing that steep hill high gear, see if it starts clanking.
Old Feb 23, 2009 | 10:48 PM
nixy's Avatar
nixy
thanks all ya its clanking just above idle is the engine gone or can it be fixed with new shells?
Old Feb 24, 2009 | 05:49 AM
No point just fitting new shells unlikely to not need at least polishing on the ends that are gone.
RB26DETT
Oct 25, 2015 05:41 PM
RB26DETT
Ford Mondeo Including ST
Aug 28, 2015 01:56 PM
Paddy
Jun 7, 2005 07:50 AM
