backend wiggling
Old Nov 26, 2004 | 10:31 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Default backend wiggling
Hi,
I recently put on series 1 wheels on my orion and if you hit a bump at 40+ the backend wiggles Is this a comon problem with putting on alloys on cars without em? Could it be the bushes or somthing like that?
Thanks
Old Nov 27, 2004 | 06:44 AM
dathers's Avatar
dathers
If it didnt do it before id check youve done the wheel bolts up tight enough pronto!
Check your tyre pressures,cant be much else if it didnt do it before.
Dave
Old Nov 27, 2004 | 06:07 PM
AKRS1's Avatar
AKRS1
had this problem once on my rst turned out the bushes had it. change all the rear bushes inc the tie rod end ones. Try to go for some uprated ones
Old Nov 27, 2004 | 06:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
check bushes and dampers m8,use to do the same with my fezzi and it was back shockie leakin
Old Nov 27, 2004 | 11:30 PM
mk1_orion_boy
Cheers for the replies, bolts are tight and pressures ok. I had a look at one of the bushes and looks bloody bad so that must be the prob!
Its quite scary bouncing towards cars
Thanks!
David
robbieg
Ford Escort RS Cosworth
Jul 4, 2007 03:27 PM
stonehavencossie
Nov 4, 2006 04:16 PM
Hooligan
May 19, 2005 01:57 PM
Hofajoab
14
Dec 30, 2004 02:32 PM
M7 COS
Oct 9, 2004 05:33 PM
