does cosworth mean trouble?
Old Nov 26, 2004 | 08:26 PM
bigal1978's Avatar
bigal1978
Default does cosworth mean trouble?
more probs tickin over at 1700 rpm y
any advice would be lovley maybe 1 day illbe able to drive it 1 hole day with out a problem
only jokin that will never happen
Old Nov 26, 2004 | 08:28 PM
dave green's Avatar
dave green
Old Nov 26, 2004 | 11:01 PM
CosKev3's Avatar
CosKev3
Default Re: does cosworth mean trouble?
You've checked the obvious things,accelarator cable sticking etc????
Also worth checking base idle screw has'nt dropped out
Pull the plug off idle control valve and see if that makes any diffrence.
Do the WD40 test,spray it all around inlet/plenum and see if idle rises,will
indicate if any gaskets sucking in air.
You've had injectors out too????Check there are no leaks where they sit in inlet manifold(O rings might be fooked)
Old Nov 27, 2004 | 06:40 AM
dathers's Avatar
dathers
You wouldnt catch me spraying wd40 all over my shiny clean engine bay!
A week later it will be smothered in dusty oily crap!.
Dave
Old Nov 27, 2004 | 08:16 AM
bigal1978's Avatar
bigal1978
done all the useual things m8 but when i take iscv plug of makes no diffrance
Old Nov 27, 2004 | 10:01 AM
CosKev3's Avatar
CosKev3
Dave
Bufty gayboy
Take boost hose off inlet and check butterfly not sticking.
Have you checked base idle screw has'nt dropped out????
And other things I suggested???
Old Nov 27, 2004 | 04:50 PM
bigal1978's Avatar
bigal1978
where is the base idle screw m8 ?
Old Nov 28, 2004 | 09:55 AM
CosKev3's Avatar
CosKev3
On the bottom of throttle body,should be a long screw with a lock nut on it if its a 2wd throttle body.
4wd throttle body has got a shitty brass screw that is recessed inside hole.
You've got my number if your stuck
Old Nov 28, 2004 | 03:24 PM
bigal1978's Avatar
bigal1978
started it up 2day and its fine
everythin works
no faults at all
well 2morros another day
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
