mk4 zetec
Old Feb 5, 2009 | 11:58 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
Default mk4 zetec
ive the relays sust (i think).. thanks tabetha.. connected everythin back up.. still no life!! she'll turn over, but u cant hear the fuel pump priming.. reckon its somin 2 do with this PATS system.. theres 2 wires connected to the 2 wires on the crank poss sensor.. how do i go about solvin this?? tabetha av a look in that big book of urs also, is there supposed to be a wire that comes off the fuel pump and lead to the ecu?? if so what pin does it go to?? any help with this would be greatly appreciated.....
Old Feb 5, 2009 | 02:09 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
pin 57 as far as i can tell mate
tommytxr's Avatar
tommytxr
the black n green wire
Old Feb 5, 2009 | 03:54 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
reckon that will turn the pump constantly on.. i,ll try it tomorrow anyways..
Old Feb 6, 2009 | 11:49 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
jus went out 2 try that tommy.. only 2 find the batts flat!! doh.. left ignition on last nite.. 57 on mine is just black and acorrdin 2 the haynes manual leads to pin 37 and a load of other sensors..... there is a black and green wire comin outta pin 51.. it aint on the haynes.. what u reckon?? i dont wanna fry this ecu...
Old Feb 6, 2009 | 12:27 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
went out and followed that black n green wire from ecu, it leads up 2 the sensor with 3 wires comin outta it on the left side of the manifold?? that aint it surely??
Old Feb 6, 2009 | 12:36 PM
tommytxr's Avatar
tommytxr
will have to dig out my old loom out of the shed cos ive just put the other in a box ready to send out
Old Feb 6, 2009 | 12:47 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
fair do's lad.. do u make them up to sell em on for mk 4s do ya??
Old Nov 26, 2009 | 05:29 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
turned out to be a simple fix.. didnt have a switched live goin to 1 of the sensors..
Old Nov 30, 2009 | 06:18 PM
mk4 kabby's Avatar
mk4 kabby
Default stupid pats
how did you get around the pats m8 .im at the current stage of finding out pats is does the pats have a separate box or is it jus connect via that ring to the ecu???
Old Nov 30, 2009 | 08:39 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
i had external pats on mine.. black box with a bunch of brown wires connected 2 it.. only 2 wires from it connected to ecu.. cut off the both wires and scrapped the external pats..
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
streetracer
Sep 24, 2015 08:14 PM
