Cosworth Experts Please......
Old Feb 21, 2004 | 08:58 AM
CosRush's Avatar
CosRush
Default Cosworth Experts Please......
Why is that on Sapph Cossies (possibly others i dont know) that the TPS is matched to the ECU.
What exactly does this mean? How are they matched?
What would be the implications of using a none matched pair?
Could anything be done to match them?
Old Feb 21, 2004 | 10:24 AM
markk's Avatar
markk
there not matched m8 !!
the differance is that on levels 1 + 6 you use a pf01
and on levels 8 , and P8 you use pf09
the differance being that the scale that the ecu reads is reversed , one reads 0-5v the other reads 5-0v
Old Feb 21, 2004 | 10:35 AM
Danny B's Avatar
Danny B
or you swap the wire round to use early one on L8 vise versa
Old Feb 21, 2004 | 11:07 AM
markk's Avatar
markk
isnt there something that , yes it will work but not properly ??
Old Feb 21, 2004 | 01:56 PM
swerv's Avatar
swerv
you need the pf09 on a l8 , swapping wires is not enough
Old Feb 21, 2004 | 02:13 PM
PJay's Avatar
PJay
I had a pf01 on l8 It depends if your mapper can map for it
Old Feb 22, 2004 | 08:15 PM
HI,
second that pfo9 for L8 ecu 4/4.swop the 2 outer wires round at plug as switch works backwards, pfo1 for 2wd L1, L6,
Dave,
Old Feb 22, 2004 | 11:25 PM
Stu @ M Developments's Avatar
PassionFords Creator
PJay,
Afraid not, it cant actually be mapped for perfect control as the PF01 goes open circuit at closed throttle and the PF09 cannot do that. That is the fundamental difference between the 2 sensors
Old Feb 23, 2004 | 12:12 AM
PJay's Avatar
PJay
Cool, cheer stu, i'm always learning
Old Feb 23, 2004 | 02:39 PM
Arent we all mate, hopefully!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
