simple swap?
Old Jan 31, 2009 | 06:04 PM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
Default simple swap?
could i just swap a 1.6 cvh 8v with a frst engine and ecu with no probs?i know i will need the intercooler but is it that easy?
thanks,Andy
Old Jan 31, 2009 | 06:06 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
thanks,Andy
well it depends what are you swaping it into?? if its say a 1.6 cvh xr2 on a carb then no as the is no loom, injection tank ect ect if you mean xr2i then its prity easy imo
Old Jan 31, 2009 | 06:10 PM
westus1's Avatar
westus1
either way you need to swap the loom ecu etc
and maybe more depending what its going into
its not a hard conversion but doesn't just fall in and run
Old Jan 31, 2009 | 06:30 PM
Andy Tucker
Welsh And Proud
its a xr2i.i thought it would just be like a plug n play swap with a few other bits,so would i need to swap the loom?
Old Jan 31, 2009 | 06:41 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
you dont have 2 change the whole loom.im sure its just abit of it on bulkhead
Old Jan 31, 2009 | 06:44 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
yes loom, ecu, fuel tank(possibly), fuel pump, driveshafts, brakes(recommended), there maybe more
Old Jan 31, 2009 | 06:48 PM
clarke5700's Avatar
clarke5700
xr2i breaks and shafts are the same as rs ones same with tank and pump the loom is the same apart from the engine harness but that is just a few pin changes
Old Jan 31, 2009 | 06:53 PM
Andy Tucker
Welsh And Proud
nice 1 boys.
engine harness?
Old Jan 31, 2009 | 08:36 PM
Toe Knee's Avatar
Toe Knee
basically on the bulkhead theres a multiplug that comes apart seperating the car loom from the engine loom, get an RS loom and it'll plug onto the 2i harness in the same place, the map sensor connector is different hence needing to change it althou you may just be able to get away with changing the connector itself......
Old Feb 1, 2009 | 08:28 AM
Andy Tucker
Welsh And Proud
nice 1 toe knee
and to evryone that replied
Old Feb 1, 2009 | 03:24 PM
Andy Tucker
Welsh And Proud
what breaks do you think would be tidy to use for the power upgrade
cossie brad
Sep 29, 2015 02:38 PM
Botts
Sep 22, 2015 02:04 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
grishenko45
Sep 9, 2015 12:58 PM
