ST170 valve float
Old Jan 31, 2009 | 03:11 PM
Rick's Avatar
Rick
Default ST170 valve float
I've heard rummours that tuners have been saying that the ST170 head won't take more than around 12psi due to valve float.
Now this is plausable, but the Americans who have far more experience with turboing this engine than us don't seem to have come across this problem.
Any thoughts?
Rick.
Old Jan 31, 2009 | 04:17 PM
jammy86's Avatar
jammy86
Surely that an issue with valve springs? Maybe they are talking about the stock ones? The yanks probably uprate them.
JAmes.
Old Jan 31, 2009 | 04:18 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
im sure ive heard of st170 heads flowing to 300 as standard? (see how i stated heard)
Old Jan 31, 2009 | 04:27 PM
crazycage's Avatar
crazycage
a standard black top zetec head will flow over 330 easy with just a set of up rated springs.
Old Jan 31, 2009 | 04:29 PM
clarke5700's Avatar
clarke5700
what about the st170 heads? saying that im on the look out for a compleat 2.0 black top head if you no of any??
Old Jan 31, 2009 | 04:37 PM
crazycage's Avatar
crazycage
ive got one here and a full set of st170 springs
Old Jan 31, 2009 | 07:08 PM
Rick's Avatar
Rick
To clarify, the yanks don't uprate the valve springs - that's the point.
Old Jan 31, 2009 | 07:56 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Americans don't really have a great record of turbocharging engines in an elegant manner, so I wouldn't worry too much about what you see over there.
The bottom line is the standard valve springs on any zetec head will cause lifters to jack up at anything over low to medium power. No point in arsing about - uprate them!
Old Jan 31, 2009 | 09:43 PM
crazycage's Avatar
crazycage
bang on the money and straight to the point as usual
Old Feb 1, 2009 | 01:11 PM
Rick's Avatar
Rick
So what are the options? Area Six are over £400 for their double spring package which seems a little excessive.
Rick
Old Feb 1, 2009 | 01:21 PM
crazycage's Avatar
crazycage
Rick
there single spring kit is only £250 and good for 20psi@7k about 25psi@6500rpm and they come with the same retainers as the double spring kit so if you ever want to upgrade you just need the extra springs
Old Feb 1, 2009 | 07:45 PM
Rs1's Avatar
Rs1
If the standard springs allow float then yeah thats got to be adressed.
Surly fitting high lb springs on hydraulics is gonna have them pumping out at the rpm your talking about?
I'm not clued up on the 170 heads, can they not take solid lifters and double springs on OE cams?
Old Feb 1, 2009 | 10:09 PM
Rick's Avatar
Rick
They are solid lifters as std.
Old Feb 1, 2009 | 10:27 PM
jammy86's Avatar
jammy86
Aren't they direct acting followers?
JAmes
Old Feb 1, 2009 | 11:35 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
try looking at some audi,s mate as they have smaller assistor springs sat inside the proper valve springs
cost effective if on a budget perhaps
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
Marv888
Sep 26, 2015 03:44 PM
