Gear box
Old Jan 28, 2009 | 09:56 AM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Default Gear box
Hi once again sorry if this has been answered.
But the cossie gearbox is 100k old.
Now whe u open her up there's a rattling noise coming from it no all the time but now and then and it feels rough gear changing when it's under load.
Also u can't put her in 1st you have to 4th 3rd 2nd 1st that way when at a stand still while she's rolling she will go straigh into first!
Just wondering what the problem is yeah i know someone's gonna it's fooked but detail please lol.
Thanks
IT'S A 2WD BTW
Thanks again.
Old Jan 28, 2009 | 10:59 AM
cos i want 2be's Avatar
cos i want 2be
is it worse when you come off load?sounds like a rebuild is in order as sounds like the bearings are shaged mate hard to tell without hearin it?if you do fined thta the gearbox is shaged then i would get it rebuilt as then you no its good for a other 100k??? good luck wi it mate!!!
Old Jan 28, 2009 | 11:26 AM
Rs Cosworth 1
RS for life
Hi mate it's perfect of boost once the boost comes on it make's a rattling noise like summat's loose but it pull's fine it's deffinate gearbox cos if i change gear at high rev's like on boost the selection of gears make a rough sorta sound and crunch in place but if i let the rev's die down before i change gear(dip clutch)then put it into gear at say 2k it's fine!!!
Just weird and oh over 80-90 mph in 5th it also starts making the noise!
cheeRS Cos
Old Jan 28, 2009 | 12:11 PM
LHD220Turbo's Avatar
LHD220Turbo
if it crunches its likely to be worn syncros; if it wont engage gears from 5th downwards t could be worn baulk rings
if its done 100k i'd just get the whole unit rebuilt rather than replace individual parts
Old Jan 28, 2009 | 12:36 PM
joffy's Avatar
joffy
SLOW LEARNER
if its in for a rebuild, upgrading the selector forks is worth doing IMO, think CTS and Reyland both do the kits, changes the tips from plastic to brass if i remeber rightly,
Old Jan 28, 2009 | 12:47 PM
Rs Cosworth 1
RS for life
Thanks COS LHD & JOFFY
All good info fanx or that
tankybaby66
Feb 6, 2016 02:24 PM
AJC
Oct 8, 2015 11:09 AM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
