Saph dash
Old Jan 25, 2009 | 07:31 PM
declan morris's Avatar
declan morris
Default Saph dash
Can anyone help. Working on my 2wd saph today and all was well until i was about to lock it up and notice the dash display wasnt working, no rev counter no ignition lights, no temp reading, no petrol tank reading nothing. The main light behind the dash was working though. Then i noticed the water starting to boil in the header tank because the fan never came on and water bubbled out all over the place, i only recently changed the thermostat as exactly the same thing was happining.
Can anybody help?
Old Jan 26, 2009 | 12:33 PM
declan morris
Any one with any ideas
Old Jan 26, 2009 | 12:58 PM
velocity's Avatar
velocity
deco what have you done to your saph,i hope this aint the one you bought reciently?
the fan problems are either , fans, fan switch,wireing, melted relay,or melted fuse board under relay,
there could be a link with the dash stuff not working but would need to consult the wireing daigrams or see the fault with my own eyes.
Old Jan 26, 2009 | 02:40 PM
declan morris
If i loop the fan switch to see if the fan comes on that would eliminate the fan not working. I where is the fan relay Velo. I will check the fuse board tonight.
Old Jan 26, 2009 | 03:49 PM
velocity's Avatar
velocity
yeah bridge out the fan switch first and see if the fans work, after that we,ll look deeper, i.ll have to look at the diagrams
Old Jun 23, 2009 | 12:55 PM
rog's Avatar
rog
Did you get to the bottom of this, have a similar problem with the dash on my 2WD saph.
Old Jun 23, 2009 | 05:44 PM
jon@work's Avatar
jon@work
have you got 12V at the black/yellow wire (ignition on) ?
Old Jun 24, 2009 | 07:51 PM
Dicko&Vacant's Avatar
Dicko&Vacant
ive also got the exact same problem at the mo except my fans work and its on a 4x4
Old Jun 25, 2009 | 06:49 AM
iansoutham's Avatar
iansoutham
OCD Victim
If the dash displays are not working, go to the fusebox and check the fuse with the diagram which looks like a brake pedal (if that makes any sense).
If fans are not working, check the 30A fuse behind the glovebox and if that is okay, check relays, switch and wiring.
Old Jun 25, 2009 | 06:58 AM
rog's Avatar
rog
Fuse number 22 10Amp, mines is ok... which means the problem is elsewhere!
Getting there though, i had alot of other problems when i bought the car so it's better than it was, and I've learned alot along the way.
Old Jun 25, 2009 | 05:25 PM
Dicko&Vacant
have you actually replaced fuse 22? as mine looked ok but changed it anyway and cured my problem
Old Jun 26, 2009 | 07:19 AM
rog's Avatar
rog
Yes
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Fordmad!
Sep 29, 2015 07:03 PM
Russ Payne
Sep 25, 2015 08:29 PM
