efi curious
Old Jan 24, 2009 | 11:30 PM
orion88's Avatar
orion88
Default efi curious
so im converting to efi but i was wondering theyre is a map sensor so where does the vacuum hose go?straight to the turbo or the ecu?and can a boost valve be fitted?pics wud be massively appreciated guys
Old Jan 25, 2009 | 12:47 AM
Smartdj.'s Avatar
Smartdj.
+1
Old Jan 25, 2009 | 09:05 AM
Are you sure the efi ecu has a vac connection, AND uses a map sensor as well, as I would not have thought so, it only needs one thing to know load so if it's in the ecu the map sensor it won't be outside as well seperately.
Old Jan 25, 2009 | 09:14 AM
crazycage's Avatar
crazycage
if you have a map sensor vacuum pipe coming out the ecu then it needs to go to the plenum
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
JESX12
Sep 4, 2015 09:16 AM
