problem on 99 fiesta
Old Jan 21, 2009 | 12:53 PM
danneth's Avatar
danneth
TORQUE!
Default problem on 99 fiesta
asking on behalf of a mate
I own a 99 Ford Fiesta and basically i have an intermittent fault which is freaking annoying. Basically when coming upto junctions the car will stall, some days it happens 2/3 times a journey other days it doesnt happen at all.
Now ive taken to it 3 garages, the last one was a Ford garage and no-one can seem to fix this.
I've had the follow parts changed/fixed:
Breather Hose
Idle Control Valve
Gear Sensor
Spark Plugs Checked
Battery Checked
Old Jan 21, 2009 | 01:04 PM
martysmartie's Avatar
martysmartie
Breather Hose
Idle Control Valve
Gear Sensor
Spark Plugs Checked
Battery Checked
CPS? Have you checked the clutch pedal switch as these can give trouble.
Kind regards,
Martin.
Old Jan 21, 2009 | 02:04 PM
I would check the CO and also the switching speed of it, a duff lambda can still pass the test but be a slow switcher, also the speed sensor, in case that is not what you mean by gear sensor ?
Old Jan 21, 2009 | 02:15 PM
GVK.'s Avatar
GVK.
Doesn't say what engine but if zetec 1250/1400 did a few pcm calibration updates back in the day for that problem. Guess Ford could have checked for that?
Old Jan 21, 2009 | 02:45 PM
Matty B898's Avatar
Matty B898
Kind regards,
Martin.
yea id say the same thing
rex647
Mar 6, 2022 06:20 AM
focus2351
Sep 9, 2015 09:33 PM
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
routemaster
Sep 7, 2015 05:27 PM
