How much boost?
Old Nov 22, 2004 | 12:02 PM
radiant red's Avatar
radiant red
Default How much boost?
I have rebuilt my rst engine using new .5 mahles, balanced bottom end with new bolts, shells etc. I have also fitted a big valve p/p head. I am using a grs front mount and a hybrid t3. When the engine is run in and set up will it be possible for me to run 20 psi on standard comp?maybe with water injection? cheers lads.
Old Nov 22, 2004 | 12:31 PM
220TC's Avatar
220TC
yes, as long as the fuel is there. You shouldn't need water injection with a grs front mount.
I had mine running at 22psi on a slightly higher spec than yours and it made 260bhp on standard comp
Do you have a performance cam, 5th injector ?
Hope that helps, Duncan
Old Nov 22, 2004 | 06:40 PM
radiant red
Yes i have a piper 285t2 and i am planning on a 5th injector. Thanks mate
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
