ST170 Spark Plugs?
Old Dec 27, 2008 | 04:29 PM
coozer's Avatar
coozer
Default ST170 Spark Plugs?
Due to my local motor factor not being able to get hold of the puka ST plugs and the local Ford dealer wanting £75 I'm wondering if the standard blacktop plugs would be OK?
Certainly the previous owner didn't have the correct ones in and as I'm running after market exhaust, ECU and carbs was wondering if the £75 set are necessary??
Cheers,
Steve
Old Dec 27, 2008 | 07:25 PM
They are nothing out of the ordinary to need a one off plug set, just find out which the NGK etc equivalent is and use those.
Some of the precious metal ones(iridium) tend to be super sensitive also, my cossie eats them quite well, lasting only around 1500 miles so use 071 now at £8 a set instead of £40 a set.
Old Dec 27, 2008 | 09:06 PM
richard_syko's Avatar
richard_syko
There is nothing special, I think they are platinum which silvertops were not. the platinum is just for longlife any ways
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
