Cossy on-boost misfire :(
Old Dec 17, 2008 | 06:10 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Default Cossy on-boost misfire :(
background is rebuilt 1500 miles ago (no new sensors ), running t34, 803's, msd chip
builds up fine, but when i try and rev it more, say past 4k, starts to miss a little and hesitate. will till rev up, but just doesn't feel smooth. have turned boost down from 20 to 13, to see if it was blowing the spark out, but no different.
popped the plugs out, 1,2 and 3 were quite black, but with a light brown tinge on the ground terminal, 4 was mainly black. couldn't adjust gaps due no knowing the right distance, but all 4 were the same.
its running ngk iridium plugs, magnecor leads of unknown age, fairly new dzzy cap and rotor and a 500 mile old grp a coil
any ideas where to look next? want to sort it before i go for a dyno setup
cheers
Dave
Old Dec 17, 2008 | 09:07 PM
dj3flow's Avatar
dj3flow
iv got the same prop did u sort yours out if sowhat was it thx
Old Dec 17, 2008 | 11:09 PM
forevaford's Avatar
forevaford
hi mate dus the rev counter go through the roof as it missfires?
Old Dec 18, 2008 | 05:04 AM
stevecossy's Avatar
stevecossy
Have you tried reducing plug gap to 0.6-0.7?
Old Dec 18, 2008 | 07:25 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Is your phase sensor gapped correctly?
What sort of condition are the leads in, check for micro holes in both the end caps on each one.
Old Dec 18, 2008 | 07:33 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
Rev counter stays normal
haven't reduced the gap, as i didn't know about weather it was the same on iridiums
whats the correct phase sensor gap? i will recheck it. leads seemed ok when i put them back on, but will have another look
Old Dec 19, 2008 | 05:08 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Seem to have solved it
took the plug gaps down to .65 and its much better
Old Dec 19, 2008 | 05:33 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
When mine had a missfire, it would be perfectly fine until 3-3.5K then would mis badly, under 3-3.5k (off boost) no probs,
Mine was the HT Leads, i borrowed a mates set first before spending Łs.
Worth a try?
Old Dec 30, 2008 | 02:25 PM
levelup3's Avatar
levelup3
Thanks for all your post, I have the same problem and now it has been sorted!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
