Please help!!!!
Old Dec 15, 2008 | 10:44 AM
sah1979's Avatar
sah1979
Angry Please help!!!!
Hi, i have got a mk3 fiesta (94), no fuel is getting to the engine, have replaced fuel pump and sender unit, had ecu diagnostic done, came back with 2 fault codes, that apparently couldnt be cleared - P2218 and P1460
Have been told needs a new ECU, but cant get the old one off! have undone the screws, but cant disconnect the wires. The engine cranks, and has a spark, and when i pour fuel or easy start into the fuel intjector (single port) it will run for as long as the petrol or easy start is flowing then die as soon as i stop,
I am Really stuck, am suggestions would be gratefully appreciated
Thanks for Readin
Shelly
Old Dec 15, 2008 | 12:13 PM
FlatheadFordV8's Avatar
FlatheadFordV8
Don't know a lot about Fiestas, but is there power to the fuel pump?
May just need a new fuel pump relay.
Another thing to eliminate anyway.
There will also be a fuel pump cutout switch, that cuts off the fuel if you have an accident. These can sometimes need resetting, but I do not know where it is on a Fiesta.
Someone else may be along soon that knows where it is.
