noisey tappets
Old Dec 7, 2008 | 09:32 PM
andy_tt's Avatar
andy_tt
Default noisey tappets
hi
ive got a problem with the tappets on 1.6 turbo. at higher revs the tappets seem to drain of oil and take a while to fill back up. i recently rebuilt the engine and checkrd the tappets when they were out and they were ok. i used to have this problem before i stripped the engine. ive got good oil pressure and running 10w40 oil. anyone had this?
Old Dec 7, 2008 | 09:41 PM
boothy's Avatar
boothy
sounds like your cams fucked mate..
Old Dec 8, 2008 | 07:16 AM
If you have good oil pressure, then either you have a supply problem to the top end, knackered tappets or duff cam.
Out of these I would say if it has done any miles and the cam looks ok the tappets are shagged, they don't last forever even if they look good as new, you can't see inside them, which is where the adjusty bit is, it's only a tiny spring on that pushes a tiny ball bearing onto a seat to hold the pressure.
davidfordrs
Sep 21, 2015 04:23 AM
Roosie
Aug 13, 2015 07:40 PM
RScrew69
Dec 4, 2004 05:25 PM
SPADGE
11
Sep 13, 2004 04:15 PM
Mar 12, 2004 08:53 PM
