st170 battery to boot conversion help
Old Dec 7, 2008 | 08:19 PM
Darren_170's Avatar
Darren_170
oval never fails
Default st170 battery to boot conversion help
hey guys, a need sum help.
am doin a battery to boot conversion and have bought a multi link box to connect all my cables into so i can run one wire the full lenght. i am going to put two fuses in the circuit as safty measures. one at the front of the car and one at the back. both are 60amp fuses. can sumone point me in the rite direction of what cable to use and if i will be fine with my normal battery if i put it in where the spare wheel should b an vent it somehow to let the gases out. how can i vent it properly.
i got another short earthing wire aswell to sort that problem out.i notice there are two earths attached to the battery in the engine bay, how do i get round this aswell.
i woud appreciate help or if sumone has a walk thru would be great.thanks
darren
Old Dec 8, 2008 | 08:05 PM
Phil2002's Avatar
Phil2002
The earths that you are left with at the front that origanally went to the battery bolt them to the chassis of the car.
A good motor factors should be able to supply you with a length of battery cable if not look for your local 'DURITE' dealer as these people make it.
Rally design and demon tweeks sell battery box's which should help you secure the battery in the wheel well.
Old Dec 8, 2008 | 11:58 PM
Darren_170's Avatar
Darren_170
oval never fails
yeah a got al ma stuff today, and was successfull with the conversion, only thing is my dash lights flicker and only my dash lights when i get higher up the rev range, this has just started as i dnt normaly have them set high, any ideas to what could solve this,
thanks
boeb
Jan 9, 2020 05:11 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
