Won't start
Old Dec 5, 2008 | 10:54 AM
alhuyshe's Avatar
alhuyshe
Default Won't start
2.9 XR4x4.
Won't start. Battery's fine, got a good spark, so I'm assuming it's a fuel problem.
Did start twice, ran for around 5 seconds both times, then stopped. Wouldn't start again till next day, then ran again for only five seconds.
Don't know these cars well at all. Where do I start?
(Have tools, have Haines manual, working at roadside.....)
Thanks, Guys.
Al
Old Dec 5, 2008 | 11:16 AM
martysmartie's Avatar
martysmartie
Fuel pump perhaps or blockage? Check under the bonnet make sure you are getting fuel to the injector rail.
Old Dec 5, 2008 | 04:59 PM
Make sure the fuel cut off if fitted has not tripped, if the button has popped up just press it in again, if no joy I would next run a seperate live and earth to the pump from a booster pack etc, then try.
Old Dec 8, 2008 | 08:57 PM
155lee's Avatar
155lee
maybe the blue cold start plug.unplug it and try starting it.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Marino
Sep 12, 2015 11:10 AM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
