Help please! -zetec pistons
Old Nov 18, 2004 | 10:05 AM
petet's Avatar
petet
Default Help please! -zetec pistons
I have recently stripped a half converted 2.0 ZVH bottom end.
It has what I thought were normal zetec pistons, but on closer inspection they have the mahle logo on the underside on the crown.
Are these normal Zetec pistons?
Please help!
Old Nov 18, 2004 | 04:30 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
No.
They are mahle, probbaly 86mm of Vauxhall origin.
Are they almost flat topped, or dished???
Either way they are forged mahle items.
Old Nov 18, 2004 | 05:11 PM
JesseT's Avatar
JesseT
The code of Mahle pistons is usually something of this type: 90V11801.
The letter 'V' means that it's cast, whereas a 'P' would mean that it's forged. The marking on the piston top tell the different sizes and gaps.
Old Nov 21, 2004 | 10:51 AM
petet's Avatar
petet
the pistons are totally flat topped with no markings on the crown. I'm pretty sure they're not the vauxhall ones as I was sure these had a small dish / valve cut-outs.
Old Nov 21, 2004 | 11:24 AM
b13nde's Avatar
b13nde
i striped my standard zetec and they were mahle, i think they are
standard for that engine did it have a spacer plate on it
Old Nov 21, 2004 | 11:56 AM
petet's Avatar
petet
no, no spacer plate - looked like a complete bodge to be totally honest! must have been lucky not to blow apart, assuming they are standard!
Old Nov 21, 2004 | 02:27 PM
sammy's Avatar
sammy
when i stripped my 2ltr zetec (pre 95 engine) to do a zvh, that had mahle pistons, i recon ford use whoever is the cheapest & mahle put in a good bid!
Old Nov 21, 2004 | 08:07 PM
b13nde's Avatar
b13nde
i think mahle are the leaders in the piston world as they are fitted to scania trucks in a 9 litre up to 16 litre they are a good piston
Old Nov 23, 2004 | 06:02 PM
richm's Avatar
richm
Yep, Mahle make standard zetec pistons...
Old Nov 25, 2004 | 03:11 PM
petet's Avatar
petet
thanks for the help - best be getting my block bored for the Vauxhall XE one's I have then
Old Nov 26, 2004 | 04:49 PM
dathers's Avatar
dathers
Why couldnt ford make a N/A engine as good as the C20XE 2ltr 16v vaux lump,wicked engines.
155bhp as standard,stainless tubular manifold as standard,cosworth designed head,early ones had mahle forged pistons and a steel crank as standard and the spread of torque is just wicked!
Shame its a vaux engine.
Dave
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
