zvh crank sensor
Old Nov 25, 2008 | 01:00 PM
rsleemc's Avatar
rsleemc
Default zvh crank sensor
hi there my car cut out the day and there is no spark av been told its a comen fault with the crank sensor on the fiestor rs av took the sensor out and it looks like it been worn down or cut down am not sure. as the conversion was already done when a bought the car does any 1 no what sensor a need to get or if a need to modifie 1. a would be greaghtfull for any help thanks. lee
Old Nov 25, 2008 | 03:59 PM
You can't mod them by wearing down so most likely it has been touching the pulley, which will kill it of course.
Any of the ford cps sensors will work if you get them fitted, but make sure of gap on ALL lugs ie set gap at nearest highest lug, as if set at a worn down/broken lug the high ones may clout it.
I would imagine the std sensor for that bottom end, is there no number left on it ?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
