What Parts to Use?
Hi everybody,
I have my 1st cossy. Its a rwd fiesta and im hoping to call on the wealth of experiance in here to help me out!! Thanks in advance!
I have just bought a new Turbo Technics T35 hybrid for it. The last T34 had small marks and like chips gone out of the blades.
Im also going to do a few small jobs like new plugs and leads and also thinking about changing the Air Filter. Currently it has a Pipercross foam filter. Would anyone have a recomendation for what parts to use?
Also would an oil cooler and a dump valve, im thinking about the GGR group A type one??
Could people put there preferred tried and tested option next to the following:
Oil:
Dump Valve:
Air Filter:
Plugs:
Leads:
Thanks.
Shane
Oil:
Dump Valve:
Air Filter:
Plugs:
Leads:
Thanks.
Shane
i have had a forge and bailys,the bailys seem stronger but the customer service with forge is excellent,i had a forge one and the lower spring broke,forge sent me new lower spring and 2 top springs for free and then when it was leaking they said send it in and they would sort it out,by then i had a bailys one and that diddnt go wrong then sold car but wait for more opinions off people who know more
For oil I use either SUNOCO racing 20W/50 or Silkolene Pro S, dump valve is a collins diaphragm one, much louder than piston types, drilled out holes to increase noise.
Air filter I have a group a cone(K&N), plugs depends on engine spec, but std and up to around 280 or so I would use AGPR12PP8, with a group a coil, 0.65mm gap, above that a set of IK31, or 071 would be safe in anything, but won't be quite as smooth low down.
I always use Magnecor where I can, don't know if you have coilpack ?, if so a ACCEL 140018 coilpack improves matters as well.
