Cossie Breaks seized
Old Nov 20, 2008 | 08:47 PM
declan morris's Avatar
declan morris
Default Cossie Breaks seized
Hi all. My front passenger calliper has seized on my 2wd 4 pot breaks. I have got the pistons out with alot of blood and tears but their out now. I just want to know about putting them back in. Do i grease the pistons with special grease or just put them back in. Has anyone any advice on this.
Cheers.
Old Nov 21, 2008 | 12:10 AM
jon@work's Avatar
jon@work
just use some brake fluid to wet the seals
Old Nov 21, 2008 | 08:05 AM
My serious advice is don't bother, get a new set.
I did mine a few years ago, new seals etc all was well, but 2 years later back to sticking, mostly down to the crappy piston material ford used.
I just weighed up all the aggro car off road etc etc, new cost Ł45 each just wasn't worth the aggro to me, but as above says just a little brake fluid will do it, try to keep as square as poss when putting in.
Old Nov 21, 2008 | 11:27 AM
declan morris
Cheers Folks, ill do this.
chowfornow
14
Jan 5, 2019 09:01 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
