saff running problem
Old Nov 12, 2008 | 11:28 AM
fizzyturbo's Avatar
fizzyturbo
Default saff running problem
the car will seem to idle fine with no probs, but as soon as i pull away the carwill splutter, and i will dip the clutch the try and get the revs up and it will cut out, but last nite when i was driving home it seemed to be fine over 2500 revs but as soon as it dropped below the rev guage starts jumping around and tries to cut out. its stage 3 tune if that helps at all
Old Nov 13, 2008 | 04:50 PM
Alvyn's Avatar
Alvyn
there could be loads of different things wrong at present but for starters I'd take the dizzy cap off and have a look at the condition of the phase sensor wires and the gap!
ps has this problem just started and now it's getting worse?
Old Nov 18, 2008 | 08:36 PM
fizzyturbo's Avatar
fizzyturbo
yeah it only started and then progressively got worse, but i traced it back to some dodgy wires by the edis, cheers anyway
Old Nov 19, 2008 | 07:03 AM
Do the wiggle test, particularly on the cps connector.
Old Nov 20, 2008 | 10:04 AM
LHD220Turbo's Avatar
LHD220Turbo
i suspect CPS as tabs says
Old Nov 26, 2008 | 09:08 PM
fizzyturbo's Avatar
fizzyturbo
seeems fie now guys i re run the wires and all seems good now, cheers
mk22door
49
Mar 26, 2022 07:15 AM
Anutternutter
24
Aug 31, 2015 01:24 PM
mrmann
Aug 20, 2015 11:24 PM
Zoggon
Aug 10, 2015 10:39 AM
ricky
Jul 31, 2015 10:30 PM
