Help needed with rs engine into diesel van
Old Nov 6, 2008 | 08:02 PM
carl ward's Avatar
carl ward
Default Help needed with rs engine into diesel van
Hi guys, im wanting to put a rs2000 setup in my escort mk6 van. my van is a 2000 model (w reg ) with the digi milometer, is it possible to put this setup into my van and still keep the digi milometer and has anyone done it as i need to know what to get, i know i need a engine, loom, ECU, gearbox, but do i need drive shafts, and i assume i need an exhaust. any info would be appreciated Regards Carl.
Old Nov 7, 2008 | 11:21 PM
siward's Avatar
siward
Not sure about the digital clock but the engine will fit straight in and should bolt to your diesel gearbox so you can keep original driveshafts. If you wanted to fit the rs2000 mtx75 box then you would have to do some work.
Si
druidgetafix
Aug 15, 2015 10:22 AM
taylora1409
Aug 12, 2015 12:06 PM
S3an
Aug 11, 2015 07:26 PM
col93saphcos
Aug 7, 2015 03:21 PM
vdubo7
Aug 2, 2015 08:17 PM
