SECS ERROR message M.A.P sensor input failed
Old Oct 29, 2008 | 08:40 PM
SS1's Avatar
SS1
Default SECS ERROR message M.A.P sensor input failed
how can i tell if my map sensor is fooked. as i keep getting the above error on my secs monitor but the car still drives ok
via the secs intruction manual it says ..
"M.A.P sensor input failed"
The M.A.P sensor/wiring has failed.
the error warning has been intermittant..but its been flashing up quite a lot today
any ideas what to check for first please cars a cos 4x4
cheers
Old Oct 29, 2008 | 08:52 PM
pee vee's Avatar
pee vee
personally i'd check the connections between the secs monitor and the loom first mate.
if the connection is dodgy/being broken, then it will flash this message up.
if the connection is good, and the car loom is in good condition, then its possible the sensor is on the way out.
Edit: unsure if it flashes this message if the sensor goes 'out of range' for the monitor?
simon will be along shortly to reveal all im sure!
Old Oct 29, 2008 | 09:06 PM
SS1's Avatar
SS1
thanks for the reply.after the first error message it flows through the warning messages ie
"Battery High Alarm limit"
"Charge Air High Alarm limit"
"Coolant High Alarm limit" and so on
but if the cars turned off for a few mins the errors seem to clear
but as i have said the car runs fine..via the loom conection is it behind the glovebox direct to the ecu ??
cheers
Old Oct 29, 2008 | 09:32 PM
pee vee's Avatar
pee vee
ah,, sounds a bit more central than that if you are getting all them messages!
possibly a faulty one then mate.
KSA-Cossie's Avatar
KSA-Cossie
Mine did that and it was the map sensor plug that was fubar.
Old Oct 29, 2008 | 11:15 PM
SS1's Avatar
SS1
ksa do i need to buy a plug or a full lead..any links that resolved your problem would be helpfull please mate.
Old Oct 30, 2008 | 07:29 AM
KSA-Cossie's Avatar
KSA-Cossie
I got mine from the guy at car looms uk from off here , ryan iirc. Just the plug did mine.
Old Oct 30, 2008 | 08:44 AM
I've got shed loads of these connectors brand new.
Old Oct 30, 2008 | 02:07 PM
Ryan's Avatar
Ryan
i got just the plug, or a new fly lead, which ever you need
Old Oct 30, 2008 | 10:15 PM
SS1's Avatar
SS1
cheers will have a look at it tomorrow in the daylight ...it was flashing on the way into work today ,,on the way home tonight not a peep out of it
Old Nov 1, 2008 | 02:09 PM
ECU Monitor Enthusiast
Avid,
Sounds like a loose wire to me
Also check the plug in the back of the monitor is firmly pushed in.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
